06-22-2018 02:43 AM
@kartiknattar wrote:
I guess this might help you.
Ohh thank you! But what I have to write in the both false case?
06-22-2018 03:37 AM
This vi will help you. Mark as solution if it works
06-22-2018 03:45 AM
It is not what I ask 😕 I try to explain better:
1) I have a boolean as control;
2) After I push the control I would like that a timer start;
3) If this boolean remain true for more then 2 seconds an indicator (led) lights on;
4)When the boolean return false, the led lights off and the timer return to zero;
5)When the boolen is true again the whole cicle will start again;
I hope so much that you could help me!
06-22-2018 03:50 AM
Hi mb,
you already marked a solution to your question, so why do you need a new thread to discuss the very same problem?
06-22-2018 03:55 AM
06-22-2018 04:00 AM
cause I am wrong
06-22-2018 04:44 AM
thank you! It was of help but I would like that after 2 seconds the led lights on, not in the same moment of the boolean
06-22-2018 04:47 AM
done! Merci!!!
06-22-2018 10:24 AM
A simple ">2" comparison in the time difference will do that.
