Detect X-axis value from a mouse click in a chart
Hi!
I'ts the first time i'm posting a question in the NI forum, so i hope i'm doing it right.
I'm using labview 2012 and I'm Trying to create and store timestamps from a real-time Aquired Data. I have a chart that display the voltage aquired from a NI USB-6343 X series on the Y-axis with the Absolute Time on the X-axis. Then the user must click on the chart and display a option for creating a timestamp with the x value from the place that were clicked and a name to that instant.
I'd apreciate any help.
Best Reagrds
Marcelo Nobre
(2,915 Views)
Hi Marcelonobre. How are you?
So I found a documentation similar. See if its what you need.
How Do I Coordinate Cursor Movement on a Waveform Graph in LabVIEW?
http://digital.ni.com/public.nsf/allkb/191A70953A91663D862574F00057423D?OpenDocument
Regards.
Erick Yamamoto
Application Engineer
National Instruments Brazil
Visite a nossa comunidade em PORTUGUÊS!!!
Certified-LabVIEW-Associate-Dev Smiley face
(2,893 Views)
Hi Erick.
Thanks for the fast reply!
Is there a way to do it on a Waveform Chart? Because i'm aquiring the data on real time and the Waveform Graph, as far as i know, doesn't support that. Is there a way to do it on a WaveformChart?
Best Reagards
Marcelo
Ps.: Vou ver o forum em portugues! 🙂
(2,881 Views)
Hi Marcelo.
In the Waveform Chart is not possible. Because the cursor function only has in he Waveform Graph.
Regards.
Erick Yamamoto
(2,871 Views)
Hi Marcelo,
you can use an event structure to detect a mouse click on the chart. Then you could use a method of the chart to calculate XY coordinates from mouse coordinates:
(2,868 Views)
