Details from a VI server reference
I have a Vi server reference from a color box and I'd like to get the Control label name from the reference because I want to use it for a case structure
(2,016 Views)
  1. What is the question?
  2. Where is the code (a file with the extension ".vi")?
(1,994 Views)
Hi Bob
The question is above and in conjunction with the attached picture. I'd like to get the label name (highlighted in red, see pic) out of the vi reverence.
(1,954 Views)
Drop a Property Node on the Block Diagram (Application Control palette). Wire your reference to the Property Node.
The property you need is Label -> Text
Paolo
(1,950 Views)
Simply place a property node on the diagram and connect the refnum to it. Then select the property you are interested in and wire it up.
Rolf Kalbermatter  My Blog
(1,944 Views)
Hoi Rolf
Herzlichen Dank!
(1,921 Views)
