Desktop Execution Trace (LV2012) hides VIs ?
I'm facing some random behaviour with DET (my understanding of DET might be random as well :-).
When tracing a projet made of VIs and sub-VIs, some of our top VIs
are not listed in the trace while their sub-VIs are.Typically, during the first run
of the project, the VI will be listed. But not for the subsequent executions.
Closing/restarting DET may also make the "hidden VIs" re-appear in the trace
the next run.
All in all, there is some relation with caching VIs in memory but I'm not able to
get a clear view on this. On the other hand, I'm pretty sure it is not a filtering
issue, this has been checked and double-checked.
I'm using LabView 2012.
Thanks for the help,
Laurent
(2,890 Views)
I have seen some undesirable behavior with DETT 2012 when dynamically launching VIs. Restarting DETT usually resolved the issue for a little while.
(2,841 Views)
After upgrading to LV2013 the issue is - apparently - fixed.
L
(2,839 Views)
