EventTrigger wrote:
We are planning to use the Compact RIO for industrial process control and logging of values for furthur analysis.
As
we are new to the NI products, would like to know, what kind of
licenses will be required for this purpose, like design time and run
time licenses. The system end-user is not interested in having a
development license at his end.
Is it possible to have only the run-time licenses at the user end?
Any help would be appreciated.
Thanks in advance...
Obviously you will need the LabVIEW development environment and
according Extensions to develop the software. So this means you will
need the LabVIEW development system and either the RealTime Extension
or the FPGA Extension or both, depending how you will setup your
applicationon the CompactRIO system.
For your end user
you would not need any specific runtime licenses as long as you use NI
hardware, since the cRIO controller comes with the necessary runtime
license already for the realtime OS on the controller and the cRIO
backplane comes with the runtime license for the FPGA code.
build applications in itself do also not need a seperate runtime
license since the development system license gives you the right to
distriibute your host application with the LabVIEW runtime engine. This
would get different if you use any of the Toolkits such as Vision
Development, Sound and Vibration, Datalogging, Supervisor and Control
or similar which do all have their ownruntime license that needs to be
purchased for every deployed application that makes use of their
functionality.
Rolf Kalbermatter
