Deployment / Run at Start Doesn't work
Having an odd issue here now that the RT SW we've written runs absolutely fine (i.e. Right click run on the main vi or via the LV GUI) and builds without error but does not run when deployed nor does it start when you've set "Run at Startup".
No errors popping up anywhere.
How can I diagnose this?
Thanks!
(1,190 Views)
Try the steps in Startup Executable Does Not Launch on Real-Time (RT) Target
https://tmesystems.net/
(1,150 Views)
When trying to open the error log in MAX from the PXI RT I get this, even after a reboot:
However getting the logs manually doesn't show anything obvious other than:
2024-05-07T13:00:02.441+00:00 NI-PXIe-8861-xxxx kernel: [ 27.220475] process 'local/natinst/labview/lvrt' started with executable stack
When I deploy the code...
(1,141 Views)
Was this ever resolved? I'm seeing the same symptoms with an LabVIEW 2026 deploying to a PXI target
(158 Views)
Nope.
Does your code run completely OK when deployed normally?
(155 Views)
Good point, we were not able to run from source and the error pointed us to the solution.
In our situation we were porting a legacy application from an old PXI running Phar Lap OS to a modern PXI running NI RealTime OS (Linux). The application had some VIs making low-level calls to DLL's which work on Phar Lap but not the the newer NI Realtime OS as DLLs aren't compatible with Linux. Ripping out the DLL calls has allowed us to run from source and for our application to run successfully.
(108 Views)
