‎04-05-2006 04:40 PM
‎04-06-2006
05:46 PM
- last edited on
‎08-04-2025
03:44 PM
by
Content Cleaner
Tom,
The CF-6004 is a Compact Flash (CF) card, so any PDA that does not have a CF slot will be incompatible. As you pointed out, the CompactFlash Association's website does not list the Dell Axim X30 as a device that has a CF slot, so I would assume that it does not. I did a quick Internet search to confirm this, and I found a site that had the following recommendation: "If you are looking for a device with a CompactFlash slot, the X50 is the one for you. If you don't need CF or VGA, I would stick with an Axim X30."
As far as LabVIEW PDA, the hardware requirements for this module are listed in Getting Started with the LabVIEW PDA Module under System Requirements. As stated in this manual, LabVIEW PDA requires either "a Palm OS device with Palm OS 4.0 or later" or "a Pocket PC 2003 device." I believe that the Dell Axim X30 is a Pocket PC 2003 device, but I will leave that to you to confirm. As long as the PDA meets this requirement, LabVIEW PDA should work.
I hope this helps!
‎04-07-2006 08:54 AM
‎04-12-2006 08:49 AM
Hey Bob,
I also have a Axim X51v with Mobile 5 and I need to do some serial comms with it... If I'm understanding this right, I can use the old MS tools and only get a subset of the LVPDA functionality, or, I can pony up the $200 for MS Visual Studio and have it running as intended. Is this right? And if so, do you have any pointers for helping make this decision?
Randy
‎04-12-2006 09:01 AM
‎04-12-2006 06:15 PM
Thanks, Bob... I'm thinking I may as well jump in and get MSVS. Sure easy to be pennie wise and dollar foolish.
Randy
