Deleting files from cRIO using WebDAV
 Hello All,
I have several log folders on my cRIO. I want to delete those files programmatically using LabVIEW by WebDAV VIs. When I delete, only the files are deleted. Folders containing the files are not deleted and it throws an error (Server has no access to files) when I try to delete it. I am able to copy the folder but not delete it. What is the issue here?
(1,238 Views)
What permissions are set on the folders?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(1,218 Views)
I have WebDAV Client with SSL Support installed in my cRIO. When I right click on any folder in cRIO and click properties, it shows "Server has no rights to change file permissions".
(1,213 Views)
Do you delete the folders after deleting the files? I can imagine folders are not deleted if they still contain files.
Any error out when you try to delete?
(1,208 Views)
Accepted by topic author PrasannaSSRK
Actually I delete files and then when I try to delete folders, it shows "Error -363516: Client does not have access to the specified resource (access is forbidden)" . Atlast, I found that Linux file Permissions is causing this issue. The solution is in this link: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kJi4SAE
Prasanna.
(1,205 Views)
