In the Data Access table one of the columns is a date format column. In some records I do not want enter date into date format cell. If I am not entering data into the date format cell, then when I am reading the cell content I get 30.12.1899--00:00:00 date. What I have to insert into date format cell so that no date will be received during the cell reading?
You may want to look into the database configuration to see if it is possible to save the date as a string that would allow you to set a "no-date" tag.
There is also the option to move to a string field and save the data manually. Also allowing you to define your own special tags for date.
