Hello all,
I've recently installed the patch LabVIEW 7.1.1, and I'm finding that 3 of my datasocketed connections using lookout protocol are having connection issues.
1. The datasocketed controls are on the faceplate of a subVI, and only the 3 controls that have their indicating LED blink between green and transparent.
2. The datasocket connections, using lookout, to tags created on a RT compact fieldpoint controller, and interfaced through the tag engine.
3. All other datasocketed connections appear to be running without a problem.
4. When this subVI is ran independent of the main VI, then all datasockets operate without a problem. The problem only arises when the subVI is ran embedded within the main.
Any ideas on what could be causing this problem would be greatly appreciated. Thanks again everybody!
