Datalog files LV v6.0 & 6.0.2
I saw a few other posts recently about datalog file conversions
between versions, but they didn't mention quite the same problem that I
just saw.
I have an application under 6.0.2 that creates datalog files. I
copied part of the application (a file reader program) to another
computer that has v 6.0. I also copied a file that had been created
under 6.0.2. When I ran the file reader under 6.0, using the datalog
type input to the file dialog function, the file would not appear in the
dialog, as if it was not recognized as a datalog file of the proper
type. The file reader program worked on both computers with that same
file once I had upgraded the 2nd computer to 6.0.2.
Is there a known compatibility issue with datalog files going
bac
kwards from such minor version upgrades? If so, is there a way to
successfully convert them?
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Research Scientist 303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
(1,817 Views)
Dave,
Thought the upgrade from 6.0 to 6.0.2 is not a large one, it was large enough to require that all VI's need to be recompiled, and also apparently, how the different data types are handled by LabVIEW has changed subtly. This would fit the criteria for why those datalog files aren't showing up, they do not filter as the "correct" data type.
I have verifed your issue and haven't been able to find a workaround, except that all copies of LabVIEW should be upgraded to 6.0.2 as a good general rule of thumb.
Joshua H.
(1,817 Views)
