Data is acted on before fully entered
I've written the attached vi, but due to my inexperience I can't see why the data is being acted on before it is fully entered.
Running COM 2 Share_2.vi, both Stepper Slave Address, and Steps can be entered, and the vi will work correctly when run.
Running COM 2 Share COM in WHILE.vi, the stepper motor will activate as soon as a new slave address has been typed and before the new value for steps can be entered.
Running COM 2 Share COM outside WHILE.vi, there is no response to stepper data.
Can anyone point out my error please ?
Many thanks !
(2,894 Views)
Accepted by topic author Placebo
In "COM 2 Share COM in WHILE.vi" the code in the loop executes repeatedly.  There's nothing in your code to cause it to wait for anything.
In "COM 2 Share COM outside WHILE.vi" the controls "Stepper Slave Address" and "Steps" are only executed one time, the values read at that time are used repeatedly in the loop.
(2,878 Views)
Sorted, thank you. I had assumed that the data wouldn't be processed by the vi until the Enter Text had been pressed, but anyway I've used a Case Structure to stop the data being processed until I'm ready.
(2,840 Views)
