Hi prosperous,
the value of the flow rate in the Front panel is NaN.
Did you even try to debug your VI?
Did you notice where that NaN comes from?
It's your use of that Formula ExpressVI and your formula!
When you divide zero by zero then you will get NaN…
Why do you wire the "interface type" for both (!) those W1/W2 inputs of the formula node?
Why do you wire the very same timestamp value to the t1/t2 inputs of the formula nodes?
Why are you doing statistics with scalar values? What's the point of this?
Why do you read some string from that USB device - but never use that string later on? What's the point of reading it?
Are you sure about using the RawUSB-type communication? Does that balance don't offer any virtual COM port?
I would really appreciate any suggestions or help in achieving these goals.
Do the training offered in the header of this LabVIEW board: learn about shift registers!
Wire the correct values to your math routines.
Use less ExpressVIs…
