10-19-2020 07:40 AM
I am using 8 channels sbRio 9627 for data acquisition and a queue to communicate data between the producer and the consumer loop. I would like to perform cross-correlation between real-time data for Channel 4 and Channel 8. If I implement the same at produce loop and its logical output shared among the other consumer loops via queue then in this process, I am getting a huge delay between the producer and the consumer loop.
10-19-2020 07:49 AM
I have only a vague idea of what you are trying to do, and have no idea how you implemented it. Please attach the relevant LabVIEW code (as VIs, or better, as a .zip file obtained by compressing the folder of the entire Project). Without understanding the Question, it is difficult to give a meaningful Answer.
10-19-2020 08:04 AM
Bob is exactly right. If you want effective answers and possible solutions, post your VI, NOT AN IMAGE OF YOUR VI.
