03-08-2019 01:31 AM
I am trying to measure nutrient solution ions continuously. I am using NI USB 6343 and LabVIEW 2017. I tried to get/record 100data per second. But, the obtained data rate was not uniform and there was some time gap (like 3, 5 or 8 seconds). I saw similar problems in the LabVIEW discussion forum. I modified the code inserting "wait(ms).VI" and replacing the "While Loop" by "For Loop". The problem remained the same. I can't understand, is it hardware or software problem? Eagerly waiting for your help...
03-08-2019 01:54 AM
Simple, use 2 different loop. One with a priority to acquire all the point and another one that do analysis and save data.
Benoit
03-08-2019 02:16 AM
Hi Bseguin,
Thanks for quick reply. I am a little bit confused about the loop (While or For Loop). I have attached a picture here. Did you mean this?
03-08-2019 02:27 AM
Not at all.
Your current solution will not run in parallel, but rater in serial.
Look at the design pattern: producer consumer, or queue.
Benoit
03-09-2019 08:08 PM
This is a "not-understanding-the-hardware-or-the-software" error. Let me explain:
03-10-2019 11:52 PM
Hello Bob Schor,
Thanks for your nice explanation. I have tried to modify my data acquisition code using "Queue" option. One of them is using DAQassist and another DAQmax. The DAQmax code shows some error. I can't understand how to fix that. In DAQassist code, I can't get my desired number of data. It gives 6~9 data per second.
Would you please check the code and find out the problem, please?
03-11-2019 07:41 AM
OK. First, you want to read the white paper Learn 10 Functions in NI-DAQmx and Handle 80 Percent of your Data Acquisition Applications. Here are (some of the) specific problems with your code:
With those changes, it should be very close to being correct.
03-11-2019 08:44 AM - edited 03-11-2019 08:45 AM
Hello Mr. Bob_Schor,
Thanks again for explaining everything. I tried to modify according to your guidelines. But the problem remained the same. 7 or 8 data per second. Would you please check the code again?
03-13-2019 03:50 AM
Would you please check the modified code because the problems remained the same... Eagerly waiting for your response.
03-13-2019 08:33 AM
Very strange. Sometimes "simplifying" can suggest what's going on. I'd suggest "simplifying" and running the following program:
This is your Producer, except (a) I added a DAQmx Start at the beginning (sometimes it will "auto-start", but I like to "be sure"), (b) removed the Consumer, simply throwing the data away, but (c) adding two indicators, one to show the loop "clocking" (it should count up once/sec, as you are sampling 100 samples at 100 Hz), and verifying that you are getting a 100 x 10 array out (it might be 10 x 100, let me know).
Bob Schor (technically "Dr. Bob", but who uses titles?)
