Data Missing in Serial Communication
Highlighted
I am Communicating an Embedded Board with LabVIEW.Data is transfering in 1 Data per second priodically.Problem is Some data are missing in between.I am using simple serial read VI.Can any one suggest me a solution? Data Log file is attached.I crossed check with some other applications in that its working fine.
:a) 329 b) 400 c) 100 d) 328 e) 373 f) 059 g) 816 h) 000 i) 000 j) 000 k) 01944 l) 000 m) --- n) 0000 o) 00 p) ---- q) --- r) --- s) xx.xx/xx.xx t) 0.35 u) 12
:a) 329 b) 400 c) 100 d) 328 e) 373 f:a) 329 b) 400 c) 100 d) 328 e) 373 f) 059 g) 816 h) 000 i) 000 j) 000 k) 01944 l) 000 m) --- n) 0000 o) 00 p) ---- q) --- r) --- s) xx.xx/xx.xx t) 0.35 u) 12
:a) 329 b) 400 c) 100:a) 329 b) 400 c) 100 d) 328 e) 373 f) 059 g) 816 h) 000 i) 000 j) 000 k) 01944 l) 000 m) --- n) 0000 o) 00 p) ---- q) --- r) --- s) xx.xx/xx.xx t) 0.35 u) 12
(944 Views)
Highlighted
It sounds like the embedded board is just transmitting data continuously. My first step would be to verify that it really is. If you read the port with something like hyper terminal, do you see a new data sample every second?
What data rates are we talking about here?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(934 Views)
Highlighted
Can you share some code?  It would help a lot if we could see how your program is put together.
Is the embedded board using a termination character?  A termination character is something like an End Of Line character at the end of each message.  If it is sending it, then make sure you are not using the Bytes At Port function.  Just tell the VISA Read to read a huge number and the read will finish when that termination character is found.  This, of course, is assuming you enable the termination character in your program.
My other guess is that you are constantly opening and closing the serial port.  DON'T DO THAT.  You should open and configure the port before your loop and close it after the loop.  You can send and read data inside as much as you want then.
GCentral
(923 Views)
Highlighted
Also, is the data being sent in ASCII or some binary format? The data seems to be varying in length, which seems a little curious.
Mike...
LabVIEW Champion
(908 Views)
