12-05-2019 09:16 AM
Hi, good morning, i would like to know if there is a way to make that a VI creates indicators for a number of exisisting informations...by example, if my VI is reading information from an exel with only 3 numbers, i want only 3 indicators, but if my excel is uptaded and now it has 5 numbers, now i want to see the 5 indicators and so on.
And how can I search for that information (names, clasification)
thanks in advance.
12-09-2019 06:10 AM
There's no way to dynamically grow the number of controls\indicators in CG LabVIEW.
You could of course use an array. That will grow from 3 to 5 without any problem. If there's only one type...
If you really want to dynamically show an unknown number controls\indicators of different types, you can put a sufficient large number* of sub panels on the FP, and populate them with the correct (saved) controls.
* Sufficiently large could be the maximum, but you can also put a few static sub panels on the FP, and make a scrollbar scroll the content...
That depends on what you want... There are millions of ways you can search.
12-09-2019 07:16 AM
You could make many indicators and controls on your front panel. Make them invisible when you start and make them visible once you add data to them. As long as you are not going to have to update many controls or indicators this method would work. If you are going to need to add or change this in the future this method might not be the best idea.
You could also put the controls and indicators into a cluster and then add them to an array. Once you fill in the information it would be available int he array. If you name things correctly you should be able to find the control or indicator and get the values from it.
