@Darren wrote:
Quick nugget this week...whenever I first install LabVIEW, one of the many default settings I change is the number of steps in the Undo history. It defaults to 8, but I always change it to the maximum allowable value, 99.
One tip that I got from one of the older LV R&D developers (but have not tried personally) is that the maximum allowed number of 99 undo steps is only due a limitation to the preferences dialog numeric input for the undo steps. You could manually change the undo steps in the preferences file to a higher number (not sure if it's a U16, I32 or something different). Just don't try to change it through the preferences interface again...
BTW, here are some of the other options that I change in a default installation of LabVIEW (directly from the preferences file, I'm lazy to translate them on the actual preferences):
- defaultControlStyle: 1
- defaultErrorHandlingForNewVIs: False
- EnableAutomaticErrorHandling: False
- autoRouteWires: False
- autoInsertFeedbackNode: False
- history.promptAtSave: True
- maxUndoSteps: 99
- SnapGridShowsOnFrontPanel: False
- StructuresAutoSizeByDefault: False
- ShowRedXOnWire: False
- skipNavigatorDialog: True
- requireAutoTool: False
- showWireGuides: False
- autoerr: 2
- doubleClickToEditControl: True
- CustomShortcuts: ";APP_SAVEAS, Shift+S;APP_SAVEALL,;APP_REINIT_ALL_TO_DEFAULT, Shift+R;APP_SC_DISTRIBUTE_ITEMS, Shift+D"
- ShowConstantFolding: False
- ShowConstantFoldStructs: False
- FancyFPTerms: False
Socratis
