Darren's Weekly Nugget 11/06/2006
Regardless of the UI difficulties, it should be solved somehow. Therefore...
This was reported to R&D (# 436990J1) for further investigation.
Message 11 of 17
(5,517 Views)
Argh!!! That's supposed to be an O in the CAR number, not a zero. Stupid display font... Why doesn't everyone use British slashes/dots in the middle of their zeros?!?!
This was reported to R&D (# 43699OJ1) for further investigation.
Message 12 of 17
(5,513 Views)
Darren wrote:
So in my case, I was drawing different components of a Picture Control, with the "Erase First" option deselected...this means that new images are drawn "over" old images, and the old images remain in the Picture Control.  Well, if two draws happened in quick succession (which was possible since I was keying off of Mouse Move events to do some of my drawing), sometimes, the first draw would never happen, due to the Asynchronous Display behavior.  As a result, portions of my picture that needed to be there from the first draw would never appear.
I've never played around with Picture controls much, so I didn't realize (until now) that it consisted only of instructions for building an image rather than a buffered copy of the image itself. So I am guessing that the rendering into a raster image is happening in the UI thread? There doesn't seem to be any way to programatically render the instructions contained in the Picture wire itself. I'm guessing you could have achieved the same by using Picture to Pixmap and then Draw Flattened Pixmap to convert the raster image back to a Picture? I'm not sure if that would have had a bigger performance hit than turning off asynchronous display, however.
Message 13 of 17
(5,298 Views)
@ok, this begs the question... How do we find out about #43699OJ1. I've seen quite a few posts from you recently that refer to "issue numbers". The question is can we see their progress/feedback/resolution? Or do we need to have a @ni.com e-mail ? 🙂
Socratis
Message 14 of 17
(4,721 Views)
The plan is that when a bug fix or upgrade is released that the public forums of DevZone and LAVA will be searched for the key phrase (which is why I have such exact wording). We'll check those CAR numbers and post to the forums that the CAR has been fixed. This is all supposed to be automated if possible.
This is something new that we're trying for the first time to try to improve the feedback to customers. We'll see how it goes next release.
Message 15 of 17
(4,720 Views)
Tried Bugzilla??? It "kind of" solves all your prayers...
Message 16 of 17
(4,717 Views)
Bugzilla was evaluated and found wanting. 😉
Message 17 of 17
(4,523 Views)
