05-30-2006 10:43 AM
05-30-2006 11:19 AM
05-30-2006 11:39 AM
I just tried this in 7.0, 7.1, and 8.0 and it worked just fine. I did notice that it only works with the Enter key on the alpha side of the keyboard...the Enter key on the numeric keypad just commits the text entry (as expected).
Ah, one other thing I just tried. This trick does not work if you have "Tools > Options > Environment > End text entry with Enter key" selected. (The path to that option in 7.x is "Tools > Options > Front Panel"). Do you have that setting enabled?
-D
05-30-2006 11:47 AM
05-30-2006 11:59 AM
Weird...only two other things I can think of...is your keyboard or OS set up for some non-English configuration? If so, maybe there's some weird key mapping going on. The other thing I can think of is to delete your LabVIEW INI file (back it up first) and restart LabVIEW and see if the trick works...if so, there's some other weird INI setting I don't know about that is killing our buzz.
-D
05-30-2006 12:11 PM
05-30-2006 02:14 PM
05-30-2006 02:26 PM
05-30-2006 02:34 PM
Argh! Yes, this nugget pertains to string *constants*, not string controls. Sorry about that.
Let's chalk this one up to too much sun this weekend.
-D
