01-02-2007 11:21 AM - edited 01-02-2007 11:21 AM
Message Edited by Darren on 01-02-2007 11:21 AM
01-02-2007 03:38 PM - edited 01-02-2007 03:38 PM
Darren,
When I try to duplicate your numeric control when I add the second value it comes up invalid. could you post the sequence to create this and the VI that you created.
thanks
figured it out I had the representation set to DBL by default
Message Edited by Jhoskins on 01-02-2007 04:52 PM
01-02-2007 03:51 PM
Hi Joe,
Change your numeric to an integer datatype and it should work...the format codes given in the screenshot are not valid for floating point values. Also, those are zeroes in the format string, not capital Os.
-D
01-03-2007 06:06 AM
01-05-2007 04:18 PM
01-05-2007 04:23 PM
Try Shift-Enter.
-D
01-05-2007 04:24 PM
01-06-2007 12:28 PM
@Philip Courtois (temporary profile) wrote:
Sweet!!!
Wonder why I haven't explored this feature before... Thanks Christian - and Darren!
You're welcome, "Master of Champions Emeritus".
Remember these things also work well for controls.
For example, try the increment/decrement button on the first three-line control.
Also note that you can change any of the three values in the first control and the others will immediately adapt accordingly. For example, you can edit the HEX part or change one bit in the binary part and all three lines will immediately reflect the new value. (Without this feature, we would probably need to invent a complicated XControl to do the same :D)
01-06-2007 12:48 PM
01-04-2008 05:44 PM
