Reply
Darren's Occasional Nugget 04/12/2019
Highlighted
You probably know that you can right-click a wire and select "Clean Up Wire":
This is handy, but (1) it requires you to navigate a menu, and (2) it doesn't support multi-select.
Did you know that you can select a wire and press Ctrl-U to do the same thing? Or that you can select multiple wires and press Ctrl-U to clean them all up?
DNatt, LV R&D
Message 1 of 10
(345 Views)
That's a long stretch even for my big hands.  Smiley Very Happy
Also Ctrl+B removes all broken wires.
aputman
LabVIEW 2017
LabVIEW Programming
Message 2 of 10
(331 Views)
All my wires are laid down neatly from the beginning, so I have no need for any of this. Smiley Very Happy
LabVIEW Champion Do more with less code and in less time
Message 3 of 10
(299 Views)
I'm midway between Darren and Christian -- I try to lay down straight wires, but I didn't know the ^U trick, and will try it out (as sometimes wires get a one-pixel "kink" ...) (and occasionally much worse, I'm ashamed to admit).
Message 4 of 10
(279 Views)
Thanks Darren for the Nugget Ctrl-U.
Certified LabVIEW Architect
Certified TestStand Architect
Message 5 of 10
(256 Views)
One of those reasons I want the default setting changed for the block diagram grid spacing too match the shift arrow.   How nice would it be to have shift arrow move things 4, 5, 8, 12, whatever number of pixels you choose
Hey, see the IEJeff is smart
Message 6 of 10
(243 Views)
I am not sure what you mean by "shift arrow" and where would you chose the distance?
In general, <shift>+arrow aligns with the nearest grid line in that direction, i e. the shift distance depends on how far away the nearest grid line is (jump is anywhere between 1 and grid spacing. If we are already aligned with the grid, <shift>+arrow will move exactly by the grid spacing).
I sort of got used to that. So you want <shift>+arrow to move a constant distance, retaining the existing grid misalignment?
Message 7 of 10
(222 Views)
Shift + an Arrow key ( up, down, left, right) moves selected things by 4 pixels on the block diagram.   On a front panel, it moves to the nearest grid space or a whole grid space up to 5 pixels.  ...silly strange behavior that should be looked at.
And,  select from tools>>options. Or VI properties grid spacing.  By vi or default for new vis,  (vi, ctl,vit, vim, ctt,  ctm,.  Etc)
Message 8 of 10
(218 Views)
Ah, emphasis on "block diagram".
Message 9 of 10
(215 Views)
As I said,   silly, strange behavior
Message 10 of 10
(197 Views)
