10-02-2013 08:47 AM
I am trying to use a high speed machine vision camera (AVT guppy PRO F503C) to analyze touch screen LCD user interface modules for pixel defects, foreign particles, scratches, etc... However, this process is hampered by a dark line of pixels which tracks down the screen continously during image acquistion (both grab and continous grab). I have had little success adjusting the camera shutter value to minimize the visibility of this line, however, this has proved to be relatively inconsistent as the shutter value seems to differ from unit to unit. I am wondering if anyone has ever run into this issue and if there is any corrective action to eliminate or minimize the effects of this line (lighting, camera settings, etc..). Here is an image:
Chase Fearing
Test Engineer
Subzero / Wolf
10-02-2013 10:56 AM - edited 10-02-2013 11:01 AM
Hello Chase,
I don't have much experience in this area, but as you've indicated it seems to be an issue with the hardware or configuration rather than IMAQ or whatever software you are using to analyze the image, so getting in touch with AVT to see if they have any input is probably your best bet.
That being said, it is probably also worth posting in the machine vision forums, located here:
NI.com forum: Machine Vision
http://forums.ni.com/t5/Machine-Vision/bd-p/200
-edit-
Looks like you've already double-posted there ( http://forums.ni.com/t5/Machine-Vision/Dark-Pixel-Line-In-Captured-Image/td-p/2578535 )- just so you know, it's unlikely that posting the same question in both forums will garner more responses, and it's generally frowned upon. Also, providing more information on the NI products you're using (software packages you have access to, in particular) and how the hardware is currently configured (frame rate, etc.) is always a good idea.
10-02-2013 11:02 AM
My guesses would be:
or
2. The frequency of your lighting. If you are using flourescent tubes, they need to be high frequency.
10-02-2013 11:26 AM
- Electrical inteference
or
I vote for #2.
10-02-2013 12:55 PM
Scott here from AVT technical support....
10-02-2013 03:47 PM
Scott,
Thanks for the input. My computer did indeed have speed stepping enabled, however, disabling it had no affect on the image aquisition. I haven't had any luck adjusting settings within the Vimba Viewer. My firmware version is: 1.00.01. There is a good chance different lighting will be required, I was just trying to exhaust every other option before investing more money into the current project.
Chase
