DaqMX turn off equipment whilst sampling
Did you see the DAQmx programming picture that I sent you? Everything before the start task should be outside of your loop. Can you make this adjustment and send me a picture of it.
      Everything before start task is outside the loop, with the exeption of the timing vi. (ill try moving that)
Can you also try techniques such as rebooting your pc or disconnecting the devices and reconnecting them again.
     Dont worry ive tried allsorts of stuff, rebooting reseting DAQmx device, setting up channels and tasks in automation explorer, deleting all channels and tasks and using virtual ones.
When im having this problem in labview i can go into measurment and automation explorer and read the channels on the DAQmx device with out any problems. (so its not a connection issue)
We know that particualr piece of code works so it's now just a case of integrating it within your project. Again it is good to run the code in highlight mode to see exactly what is causing the error.  At the moment is the error occuring at the Create Virtual Channel vi?
Yep
Thanks, Zac
Message 41 of 41
(504 Views)
