11-14-2019 03:07 AM
>When you want to save data to file even when one of your two DAQmx tasks gives an error >then you should NOT wire that error cluster into the WriteFile function: when an error is >present at error in it will not write any data
I understand this... but should it write the data at all if there is an error?
Would you rather go around the for loop with the error wire and plug into the OR function directly from merge errors (after RDI subvi)? Thanks
11-15-2019 02:31 AM
Hi Davide,
That depends on your requirements…
I guess you should write data even when one of your two tasks is giving an error!?
