06-27-2011 04:30 PM
Hi otlm,
Are you using a hardware device with this example? Have you added the VI to a project? Based on your comment, it seems like you may have done this, but here is a tutorial that talks about adding the VI and the hardware to a LabVIEW project. Do you get a specific error when you run the VI that triggers some sort of failure? If you get an error, please post that to the discussion forum. Thanks!
Kim W.
06-28-2011 12:29 PM
I answer the questions in the topic named "DSP FFT problem".
