All;
The following bit of code (StringRowAdd) mem-faults in a LV-called DLL, the other code (StringAdd) works fine. Can a programming god figure out what I'm doing wrong here?
...Dan
void StringRowAdd(TD4Hdl in_array, char *string[], int cols)
int i=0, j=0;
j = (*in_array)->dimSizes[0] * (*in_array)->dimSizes[1];
(*in_array)->dimSizes[0]++; if (j == 0)(*in_array)->dimSizes[1] = cols;
for (i=0; i
(*in_array)->String[j + i] = (LStrHandle)(DSNewHandle(sizeof(int32) + strlen(string[i])*sizeof(char)));
/* (*(*in_array)->String[j + i])->cnt=strlen(string[i]);
strcpy((*(*in_array)->String[j + i])->str, string[i]); */}
void StringAdd(TD2Hdl in_array, char *string)
int i, j;
j = (*in_array)->dimSize++;
(*in_array)->String[j] = (LStrHandle)(DSNewHandle(sizeof(int32) + strlen(string)*sizeof(char)));
(*(*in_array)->String[j])->cnt=strlen(string);
strcpy((*(*in_array)->String[j])->str, string);
typedef struct {
int32 dimSize;
LStrHandle String[1];
} TD2;
typedef TD2 **TD2Hdl;
typedef struct {
int32 dimSizes[2];
} TD4;
typedef TD4 **TD4Hdl;
