DSC ver. 8.5 I cant read the properties of a shared variable from an executable Labview application
My problem is that I create a very simple application on labview DSC 8.5.
An I/O server with only three variables . I configure this variables with High and Low Alarm setting. Alarm condition is enabled
Then with the attached  labview application I change the Hi alarm Level  of this variable and everything is working fine under labview enviroment
B U T if you run the same application on exe mode then the shared variable property does not working
Any suggestions
Giannis
Athens Greece
(4,273 Views)
