DSC Read Trace Interpolation Bug
I have found that data traces read from my Citadel DB using the DSC read trace vi with interpolation enabled introduces anomolies into the resulting extracted data sets.
All of my data is sampled at 10hz with a .1s interpolation interval on historical reads.  If I export the data from MAX then everything looks good (with all interpolation types).  If I do the same with DSC then strange flat spots are introduced in the data.  I have included images of the MAX and DSC versions.
DSC Data:
MAX Data:
(2,943 Views)
Can you elaborate on the exact process of getting this data into Excell?
Can you post your VI that uses the read trace VI?
What are you expecting to see?
(2,912 Views)
