04-28-2010 02:57 AM
im Running an SCTL on my FPGA. In this SCTL i read 10 times 8bits that have to be transferd to my Host system via DMA Fifo.
If i would have 64 bit instead of 80 bit i simply would use the Join Numbers Function and use a U64 Fifo.
So what can i do?
Is it possible to create a 80bit Datatype?
Or can i input 2 Values into a Fifo in an SCTL some how?
Thank you for your help
westgate
04-28-2010 12:03 PM - edited 04-28-2010 12:04 PM
I would accumulate the bits on a shift register until you reach a block (64 bits) or the end of the data. I would then transfer each block (64 bits) via DMA to the Host. i do this all of the time. See See my 1-Wire sample code
04-29-2010 05:13 AM - edited 04-29-2010 05:14 AM
well my application is time criticall.
I would like to output all 80bit at once every SCTL loop iteration.
So your solution is good but maybe not the right for me.
westgate
04-29-2010 10:45 AM
You could write to a FIFO within the SCTL and read the FIFO and use a DMA to move the data to the host.
Since 64 bits is the most can move at a time I would transfer 40 bits on each DMA transfer and put the data back together at the Host.
