10-25-2016 06:17 AM
10-25-2016 06:57 AM
10-25-2016 07:06 AM
10-26-2016 03:23 AM
Hi there,
The 7975R has an x4 PXI express connection, whereas the 7976R has an x8 connection, allowing for higher bandwidth to the host.
You can see this on page 4 of the specifications for the two cards, beyond this, i cannot see any differences;
If you would like to discuss these cards in more detail, give us a call on (+44) 1635 523 545
I hope this has helped!
-Michael
10-26-2016 03:43 AM - edited 10-26-2016 04:03 AM
Hi Michael, thanks a lot for your answer! I didn't notice this when reading the specs.
The difference in connection that you mention, this is a hardware difference?
10-26-2016 04:01 AM
Yes this is a physical difference in the two cards, the x4 or x8 refers to the number of lanes that exist for your data to travel down, this is explained quite well here;
Specifically this section;
What does x1, x4, and x16 mean?
With PCI Express, data is sent serially through pairs of transmit and receive connections called lanes, which give data the ability transfer at 250 MB/s per direction. Multiple lanes can be grouped together into x1 (“by-one”), x2, x4, x8, x12, x16, and x32 links to increase bandwidth to the slot. For example, a x16 slot would have bandwidth of 4 GB/s per direction (250 MB/s * 16).
Let me know if you have any more questions!
-Michael
10-27-2016 11:07 AM
Michael,
You stated:
The fact that you mention 'host' confuses me. The bandwidth to which you refer is that of the connection between FlexRIO and whatever the FlexRIO is connected to? In my case the FlexRIO is connected in a slot to a chassis (1085). Hence, in this case we are talking about the connection between FlexRIO and the switch in the backplane, correct?
10-28-2016 03:57 AM
Yes, in the same way that the "host" would be the PC for a PCIe card, in this case, the "host" for a PXIe card is the controller and backplane.
-Michael
