05-04-2006 11:59 AM
05-05-2006 04:09 PM
Hello Matt,
I do not know of any additional configuration that MAX does to allow you to use
your hardware, and I am a little unclear on what exactly you are
experiencing.
Are you saying that after installing the driver and your device you had to open
max and use test panels before your device would work with your application,
and now you can always use your application (even after restarting your
computer) without opening MAX? Or, are you saying that you can never use
your application unless you open MAX first? In the second case, MAX maybe
performing some initial configuration of the device that is should be performed
in your software. Does this behavior only occur with your software, or
does it occur with a shipping example too?
Are you using LabVIEW to communicate with your device? If so, what
version and what driver have you installed. If not, what programming language
are you using? Is this driver version the same that you had
installed when you developed your application? What operating system are
you working on? Do you need MAX open to run your application, or do you just
need to run it before your application? Any additional information you can
provide about what you are experiencing would be helpful.
Jesse O.
Applications Engineering
05-05-2006 04:40 PM
I am saying:
Are you saying that after installing the driver and your device you had to open MAX and use test panels before your device would work with your application, and now you can always use your application (even after restarting your computer) without opening MAX? - Yes
Does this behavior only occur with your software, or does it occur with a shipping example too? - I Have not tried to run example after a fresh install so don't know
Are you using LabVIEW to communicate with your device? - Yes LabVIEW 8.0
If so, what version and what driver have you installed. If not, what programming language are you using? - NI DAQmx 8.0 for Feb 2006 Disk
Is this driver version the same that you had installed when you developed your application? - No, previous version
What operating system are you working on? - XP
Do you need MAX open to run your application, or do you just need to run it before your application? - Just run once and close before running application
Any additional information you can provide about what you are experiencing would be helpful.
I spoke the the engineer who gave me the information and he said it happens only some of the time. Most systems come up fine but a few require that MAX before the app will run correclty.
Matt
05-06-2006 05:49 AM
Matt
Not sure if this is related or not but I will share it with you just in case there is common ground.. I had a NI-DAQ to drive the DIO24 (PCI-6503) and then converted it to DAQmx. I found that the DAQmx didn't work at all. I found way a way to get around this by doing a Reset Driver under NI-DAQ in MAX. There after the DAQmx application would run with no issues.
Its almost like the NI-DAQ driver was preventing access from the DAQmx driver but the resetting the Ni-DAQ driver did the trick.
Might help...
David
05-08-2006 06:56 AM
Sounds like the same issue I am having. I did not have any issues with the per-DAQmx driver. At least the work around is simple.
Matt
05-08-2006 12:22 PM
Matt,
That sounds very likely. When you open test panels in MAX, you force that
driver to take over control of the card. If the traditional driver had
the card, after running test panels in DAQmx, any DAQmx software will now work
that did not before.
I could verify this if you still have the error number that was produced when
you tried to run your application.
Jesse O.
