I'm trying to use DIO Port Config to control an scxi 1161 switch module.
I have used an example from NI for a few years and it worked well.
However now I have NIDAQMX and it will not run. When I try to set up the port number
as SC1Mod1 versus sc1 ! md1 ! 01 , I get the error message:
NI-DAQ LV: An error was detected in the input string; the arrangement or
ordering of the characters in the string is not consistent with the expected ordering..
Can Iuse this VI under NiDaqMX or do I have to alter it.
It will run correctly if I configure the 1161 under traditional NiDaq, but I need to use NiDaqMX.
Also I use this VI a lot to control external relays for switching signals to the DMM and
I want to be able to use it as it works great for that application.
Any help appreciated.
Thanks KS
