11-04-2019 03:32 AM
I have an issue with DETT. I created custom API, tested it, it works fine. It has user defined events, which I can track through DETT. Also, VI call/return traces show properly in DETT, when a VI is called/closed. Then, I build VI package through VI package manager. When I try to use this API under same circumstances as the one before build, I cannot see any traces for API VIs anymore - neither user defined, nor VI call/return. Since I am using completely same options as before, my guess would be that it has something to do with VI package manager building process. Can anyone share any insight please, what the issue might be?
Solved! Go to Solution.
11-04-2019 05:13 AM
Finally I found what caused the issue - my toolkit´s API was installed to vi.lib and by default, vi.lib VI´s are excluded from DETT in Capture Settings. Hence, simple checkmark in Capture Settings did the job. 🙂
