DCS does not update when file saving windows appear
I am using LabView (with Fieldpoint opc) to control plant operations. When I save a labview file and the Save the VI window appears
with the files/directories etc, everyprocess running on the computer freezes, input/output data from fieldpoint does not change
until the Save the VI window is gone (ie file saved or cancel pressed).  This is not a very good situation for realtime online control
of processes.
                                 Brendan Veilleux  PTX Food Corp
(2,369 Views)
Hi Brendan,
Can you tell us a little more about your application?  From the title, it sound like you're using the DSC Module.  Is that correct?  What are you doing in the VIs?  Is the VI that you're modifying part of the running application?  Do you have any VIs running on the Fieldpoint?
Jared S.
Applications Engineering
(2,355 Views)
