DC motor signal
Hello all experts,
Now I have a project about automotive,I want to check DC motor signal :phase_U,phase_V,phase_W
as attached picture.
However,I don't know how many test items need to be performed.
Anyone can help me,thanks
Albert
Message 1 of 10
(3,746 Views)
What do you mean Test items? Do you want to measure the values at MOUTs?
 Or do you have some sort for algorithm for performing some math operation. Please explain.
Message 2 of 10
(3,734 Views)
Boy that is one studly 8051 you are using there! In any case, to measure the three outputs you will be needing 3 analog inputs.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 10
(3,716 Views)
I guess PC send commands to the controller by UART or other communication protocol  then MOUT0,1,2 will output signal.
So we will check this signal to make sure DC motor fuctionality good or not.
Test items means voltage ,frequency ,THD,and so on.
If DAQ card can check this fuction or need Oscilloscope?
Thanks a lot
Message 4 of 10
(3,703 Views)
Yes,i want to check Mouts values,thanks
Message 5 of 10
(3,702 Views)
Message 6 of 10
(3,702 Views)
Do you know what the large IC in your schematic is? It's a variant of an 8051 microprocessor. It does whatever its program tells it to. How is it programmed? From what is there, I can't tell if it even has a serial interface on it -- or how it might be used.
Mike...
LabVIEW Champion
Message 7 of 10
(3,675 Views)
Thanks for your information.
Yes,I know larger IC is microcontroller,also know it would be programmed before used.
Now there is no any useful information about programmed code and its fuction.
But even if missing much information,I must make test plan to customer.
I just want to know how to test MOTOR signal in normal method.
Check freq,THD,voltage....etc?
If DAQ card can meet this test requirement?
Or need to use oscilloscope?
Message 8 of 10
(3,669 Views)
Yes, you can use a daq card but you must know something about the signal in order to select the correct one. You just can't blindly assume anything. What sort of sample rate, simultaneous capture, maximum amplitude, etc.
Message 9 of 10
(3,659 Views)
well, assuming that whatever the uP is in is operating, It might be useful to look at the outputs with a o'scope to see what the data there actually looks like. This will tell you things like amplitude and give you some insight into the sort of sampling rates you will need.
Mike...
LabVIEW Champion
Message 10 of 10
(3,644 Views)
