DB tool kit, multiple computers opening and closing connections
Highlighted
Silly question, but I'm paranoid and unable to test this while working from home. Multiple computers running the same program. Is there going to be an issue/race condition problems with the DB open connections and close connections running at the same time?
(351 Views)
Highlighted
BTW using Microsoft SQL for the database.
(328 Views)
Highlighted
A "good" data base will handle that for you. You will want to have good error handling in your program.
(309 Views)
Highlighted
Accepted by topic author breezy45
This is generally only an issue with a file based database like MS Access or SQLite.  I haven't actually done this, so I can't comment directly, but theoretically server-based databases like MS SQL should handle concurrent connections with no problem.
(298 Views)
Highlighted
By the way, DB tools kit,is only for sql server ?
For mysql, which tools we should use ?
Thanks.
Keep moving
(157 Views)
