02-12-2016 04:32 AM
Open and write to an access.accdb runs without error, but when I want to close the connection reference, the VI hangs. Only close task helps. This appears since the last Office/Access update. The behavior is also in applications that I created before the updates.
Our IT department tries to restore the status before the updates.
I'll keep you informed
Andreas
Solved! Go to Solution.
02-12-2016 07:49 AM
02-15-2016 01:56 AM
Mike,
my Windows is version 7/32, Labview 2014. Definetly this VI hangs in invoke-node close.
Neither the IDE works nor compiled applications. But they did before the access update run, also on different machines. Our IT is searching for it. One suggestion I heard maybe an antivirus definition file. We'll wait and see.
Andreas
02-15-2016 02:31 AM
Here is closer information about the update. Sorry it's in German ...
02-15-2016 03:16 AM - edited 02-15-2016 03:19 AM
Hey AndreasC,
the update you just posted (KB3114731) is an Junk-Mail filter update for Outlook. I think is the interesting one:
February 9, 2016, update for Access 2016 (KB3114522)
https://support.microsoft.com/en-us/kb/3114522
Is there any error you receive from LabVIew?
Greets
Brandizzl
02-15-2016 04:09 AM
Hey Brandizzl,
labview returned no error message. When i run in debugging mode I see the vi hanging (green arrow stops in the vi). Inside the VI it hangs in the invoke node (close methode).
Meanwhile our IT department solved the problem. They excluded some branches of the antivir definition paths they distributed with the office update.
Andreas
02-15-2016 04:12 AM
So is your program running again?
02-15-2016 04:16 AM
Yes, all is fine. apps and the IDE
