DAQmx port configuration
My question is on port configuration.
I am using USB-6509 and SCB-100
I usually get an error if I configure Port 3 Line X as input and Port 3 Line Y as output.
Can a single port with different lines can be configured as different types (input or output ) ?
(2,586 Views)
Accepted by topic author VikashKumar23
Hi VikashKumar23,
From the USB-6509 manual on Page 12 it also says "You can configure the direction as input or output on a per-port basis." so I'd imagine not.
Hope this helps,
Rebecca
(2,539 Views)
