07-14-2011 12:31 PM
Thank you Rodrigo.
When you talked about "samples per channel" I thought you where refering the "samples per channel" input in DAQmx Timing vi, which sets, as I realize now, the buffer size when "sample mode" is continuous.
I realize now that when sampling at a rate of 1000S/s the smallest buffer size allowed is of 10kS, so my setting of 100S was useless.
Setting the "number of samples per channel" allowed me to remove the "wait" i had in the while loop.
Resuming: the problem arouse when trying to save measurements from NI-9236, which has a minimum data rate of 794S/s, with a lower frequency (this is particularly necessary for "structural static tests"). This was solved by setting a 1000S/s (I prefer round numbers) and a "number of samples per channel" of 20, resulting in a 50Hz data logging. I'm not sure this is the best way to go but it clearly worked.
07-14-2011 12:40 PM
Hi Jeff,
I followed your first advice. (Changed "Start task" with "Control task" + "commit", and "finite samples" for "sample mode").
This worked for a while until I got this error message:
This error showed sooner or later, depending on the "Buffer size" I set.
I have never used the producer-consumer structure, I will try it soon.
Regards.
07-14-2011 04:17 PM - edited 07-14-2011 04:22 PM
Make sure you Read the Number of samples you set in the timing node. The task stops after it acquires the number of sample set in the TIMING vi but the Read vi returns just as many samples as you ask for- (leaving some old stuff in the buffer that will eventually get overwritten.
I put up a example PC stae for DAQ a bit ago I'll check my images and post a link
Here is a link to a similar thread with an example of a P-C DAQ system
