04-26-2008 09:20 AM
04-27-2008 09:39 AM
04-27-2008 09:50 AM
04-27-2008 03:33 PM
04-27-2008 07:17 PM
04-28-2008 10:49 AM
Hi Lawrence,
The differential channels are not
assigned as 0-15 on the NI 9205. They’re actually paired in groups of 8, so the
differential channels are 0-7 and 16-23. This is in the NI 9205 Operating
Instructions and Specifications (February 2008) manual under the “Differential Measurements”
section. You will notice that the pins are physically located side-by-side as a
pair (seen in MAX device pinouts or the above manual).
xseadog is right when he said that if you choose a non-differential channel the option for differential disappears. This is true when using test panels or an Express VI. If you are doing this with the discrete DAQmx VIs, LabVIEW will allow you to choose any channel from the drop-down. However, if you are selecting a non-differential channel number with a differential configuration, you will get an error.
I threw a VI together to show how you
could choose the 16 differential channels and the configuration of the DAQmx
Create Channel VI. I hope this helps.
04-28-2008 11:12 AM
