DAQmx: How to calculate the phase error through interchannel delay?
Hello community,
I am using a PCI-6259 to aquire a sinewave (f=10 kHz) with 7 channels. Because of the multiplexer I habe a interchannel delay between the different channels, which results in an phase error.
I can get the multiplexer-frequency over the property node (1MHz for the 6259). But how do I calculate the phase error with this information?
Thanks a lot and best regards,
Michael
(2,886 Views)
I assume that you need to acquire 7 different waveforms, one channel for each.
You may perform an initial calibration (fed all 7 channels with the same WFM, and read the delay).
Have a look also at this discussion:
http://forums.ni.com/t5/Real-Time-Measurement-and/pci-6259-time-delay/m-p/1113690?requireLogin=False
Grüße
(2,879 Views)
