DAQmx Data acquisition tools
I'm getting errors on start Task vi see attach DAQmx 1
I'm usingLabVIEW 14 and a USB 6009 and 2 USB-TC01 all 3 are in MAX
the program is intended to address 2 16 channel Mux chips and display 30 + channels of data.   VI attached too
I have tried many hours to solve the issue of no task name, somtimes it works but then the errors return.  I hope to get some help point out what I'm doing wrong
Thanks in advance
Gene
(2,474 Views)
Accepted by topic author justgene
You can only have 1 analog input task on a DAQ.  But you can have multiple channels in a task.  For instance, for the Dev3 channels, have the channel be "Dev3/ai0..2".  That will have all 3 of your channels in a single task.  Then you just read all of them in a single DAQmx Read (N Channels, 1 Sample).
GCentral
(2,464 Views)
Crossrulz,
Thanks for the rapid responce!  I'll do some rearranging and try your solution.  I'll be sure to post the results
Thanks again!
Gene
(2,457 Views)
Crossrulz, your information was the solution to my problem thanks!.  I had to rearrange the array scheme, terminate the tasks, handle errors etc but I think this is going to work
Gene
(2,400 Views)
