Hello All,
I was trying to generate a single pulse generator with external clock pulse and Start Digital Edge. See the attachement VI
Everytime when I a command is given I will call this subVI to generate a Single Pulse of said duration(Ticks) from the reference pulse (Start Digital Edge).
But while running this, I had noticed that some times the Counter Output fail to generate a pulse, say 1 in 3 times.. But if I remove the Start Digital Edge VI ,its working fine for every events. I am very sure the Trigger Pulse is not missing because 'Z' pulse from encoder is wired as trigger input.
What could be the reason why I CO fails to generate the pulse?.
Many thanks in Advance..
