DAQmx 19.0
Hello David,
Thanks for sharing those with us. It helps clear the options we have to have it working for you. I recommend we uninstall NI-DAQmx 19 and load 18.6 to make sure it is using the version that states 3.0 as supported in the readme. This should allow NXG to see the device and work with it showing the DAQmx tools. Can you confirm if this step does the trick?
Message 11 of 12
(507 Views)
Oscar,
Installing  DAQmx 18.6 resolved the issue.
Thank you for sticking with me,
David.
Message 12 of 12
(495 Views)
