12-18-2017 05:44 AM - edited 12-18-2017 05:46 AM
i am using labview 2017(64 bit) on windows 7 and installed DAQNavi_SDK_4.0.4.0 to use DAQNavi assistant but whenever i open DAQNavi assistant function from search palette and place it in block diagram window, it doesn't open DAQNavi wizard but instead it shows a line of window through which i can't edit any of it's properties. please refer to the attach image.
12-18-2017 08:01 AM - edited 12-18-2017 08:02 AM
Have you contacted Advantech? Is this product supported for 64-bit LabVIEW (which was not quite as functional in 2012 when DAQNavi was released)? Note that there are a bunch of things (often related to DAQ) that are not quite ready even now for 64-bit LabVIEW ...
12-18-2017 10:04 PM
yes, this product is supported for 64 bit labview but somehow not working on my PC.
12-19-2017 07:08 AM
12-21-2017 02:31 AM
Thanks everyone who replied to the post .
i find out the solution by installing different version of DAQNavi SDK and it worked.
02-14-2019 01:46 AM
bendawson Please can you seed me your solution i'm block in my application in CVI and i will try the labview thank you soo much
06-25-2020 07:58 AM
Hello, can you lead me to download and add DAQNavi in Labview 2017 ? thanks.
