08-01-2007 06:43 AM - edited 08-01-2007 06:43 AM
Message Edited by Nallez on 08-01-2007 06:43 AM
Solved! Go to Solution.
08-01-2007 07:45 AM
First key question: is it really necessary to stop and re-start the task? Or is there another way to accomplish your purpose? For example, if you stop and re-configure to be sensitive to transitions on different DIO lines before re-starting, you might be able to take the following approach:
- Configure hardware once to be sensitive to any transitions you're ever interested in.
- Configure a software filter that can evaluate the changes acquired and decide if they are the "right" ones.
- Instead of stopping, re-configuring, and re-starting the hardware task you would just re-define the software filter parameters for a new definition of "right".
-Kevin P.
08-01-2007 07:56 AM - edited 08-01-2007 07:56 AM
Message Edited by Nallez on 08-01-2007 07:59 AM
