08-24-2012 06:25 AM
Hello to all,
Actually, I am a super amateur of using labview.
Currently, Im using USB-6008 to analyze vibration of wind blade with 4 accelerometers.
However, I can not collect 4 channels' voltage outputs with my labview modeling.
If possible, would you like to let me know how to modify my labview modeling to collect 4 outputs at the same time??
Solved! Go to Solution.
08-24-2012 06:42 AM
Hey,
The DAQ Assistant looks to be configured to read 4 voltages and output it as a Dynamic Data Type. The problem lies in your Convert from Dynamic Data Express VI. You need to change the Resulting data type to be a 1d array of waveforms.
If your new to LabVIEW, you may want to look at this:
LabVIEW Training: Learn LabVIEW in Three or Six Hours
Kind Regards
Lewis
08-24-2012 07:16 AM
Thanks for the feedback.
it means do i need to use 1d array??? which type of 1d array do i need to use???
I can see that there are over 8 1d array types..
I need to finish the measurement before todat evening, so I do read the tutorial now..
Please help!
08-24-2012 07:46 AM
08-24-2012 10:21 AM
It works really well!
Thank u very much!
