DAQ packed in (Windows 7?)
   I set a load test running this weekend on a PC running Windows 7. The test only lasted 3 hours before a LabVIEW error stopped it. This is a test that has worked flawlessly for days and days on other machines (XP) - the only thing that I can see that is different is the OS. has anyone else had a similar problem, or can tell what this is about?
Here is the error I received.
Many thanks, Alec
Possible reason(s):
Measurements: Device not available in NI-DAQmx. It is possible that the device is being used by Traditional NI-DAQ or that the device is being reset.
After using a device in Traditional NI-DAQ, you must reset the device before using it in NI-DAQmx. For SCXI devices, you must reset the communicator DAQ device. Call the Traditional NI-DAQ Device Reset VI or the Init_DA_Brds function. To reset all devices in Traditional NI-DAQ, right-click the Traditional NI-DAQ Devices folder in MAX and select Reset Driver for Traditional NI-DAQ. If you are resetting the device, wait for the reset to complete.
Task Name: Pager 2 Button 1
Message 1 of 11
(3,945 Views)
Message 2 of 11
(3,935 Views)
Hmm, the above link seems to reference DAQ devices that have not started up. My started up find and ran for several hours, this does not explain why this happened 😞
Message 3 of 11
(3,932 Views)
Also, I am using DAQ-mx objects within my code, and don't understand why the traditional DAQ should be hijacking it.
Message 4 of 11
(3,930 Views)
Message 5 of 11
(3,929 Views)
this option is not available to me as I do not have any traditional DAQ devices on my computer
Message 6 of 11
(3,926 Views)
That is strange.... Then where is the clash happening???:smileysurprised::smileysurprised::smileysurprised:
Message 7 of 11
(3,921 Views)
Attached is the Measurement and Automation Explorer log that was created after the error occured.
Message 8 of 11
(3,918 Views)
alecjcook,
What is the model # of your DAQmx device?  Is this a USB?  PCI?
Message Edited by Wayne.C on 03-22-2010 09:41 AM
Message 9 of 11
(3,888 Views)
sorry, it's a USB-6501
Message 10 of 11
(3,878 Views)
