DAQ multi-channel analog output at different times
How to configure the DAQ multi-channel analog output at different times, respectively, that is, the two channel output in sequence?please thanks
(1,237 Views)
Accepted by topic author
While it may not be universal, the analog output of module generally share a common clock so multiple channels are combined into a single output task and started at the same time.
If the outputs are on separate cards, you should be able configure them using unique tasks and start them as you need.
Ben
(1,226 Views)
